TO-35 Glow Plug wiring
Tom
06-06-2003 05:28:44
How do you wire the glow plugs on the Standard TO-35 Motors Diesel? Do you come off the voltage regulator or is there a resistor in the circuit etc.
David
06-11-2003 17:21:23
 Re: TO-35 Glow Plug wiring in reply to Tom, 06-06-2003 05:28:44
See reply above at FE35 starting post. Don't know if my guess is right. Are you certain they are the correct plugs?
Tom
06-12-2003 07:57:24
 Re: Re: TO-35 Glow Plug wiring in reply to David, 06-11-2003 17:21:23
yes they should be the right plugs. I got them from the local MF dealer. Maybe I should try fitting it with some that will take the current from a 12 volt battery but they all may require some ballast in the circuit. Thanks. Tom
