MF-35 trans. oil
Rod
06-05-2003 14:39:50
I have a mf 35 I want to change the transmission oil can anyone tell me what oil to use? Thanks for any info.
ron elliott
07-07-2003 10:40:57
 Re: MF-35 trans. oil in reply to Rod, 06-05-2003 14:39:50
i have same problem you have and have been warned against using anything but a mineral based oil. what have you found out, if you don't mind. does mineral based mean no petroleum products??
smokey
06-07-2003 17:52:25
Check with your supplier - most have data online. I use shell donax 90 but it is quite warm here. Select a basic oil rather than getting to smart with an oil that may affect your hydraulics. You will need more than 5 galls if you change it so check carefully and clean you hydraulicfilter prior to refilling. Big dean probably has instructions otherwise check old entries on this board.
