MF1085
Grant
06-04-2003 14:46:43
I just sheared my PTO shaft off, there is still about 2 inches sticking out of the bearing. Still working, although the PTO brake doesn't stop it completly.
Is this going to be a pain to fix? It looks like I just need to unbolt the PTO bearing housing and pull it,then hopefully the shaft will come out the back. Does this sound right or am I going to need to approach this from the front and split the tractor?
I'm not worried about the PTO brake at this point(although I realize it is dangerous). Any help would be appreciated. Thanks, Grant
Mark
06-05-2003 05:41:21
 Re: MF1085 in reply to Grant, 06-04-2003 14:46:43
You are correct in that the pto housing will unbolt from the tractor, and can be taken out of the bearing.Those tractors had 540 or 1000 rpm shafts available for them and that is how you changed them.
