Fe35d low power
kim
05-31-2003 10:55:30
My 35 has a professionly rebuilt perkins diesle,including head and injectors. No problems with oil or water,has white smoke when not loaded no smoke loaded.The tractor is used to drive PTO waterpump . The pump is new and requires 15hp,It slows my tractor down so much that it makes no difference beteen half and full throttle and the pump is just over half of its operating pressure.I have installed new fuel filters serviced air cleaner.Could it be injector or primary pumps both untouched.
David
06-03-2003 11:05:32
 Re: fe35d low power in reply to kim, 05-31-2003 10:55:30
Since no one else has any ideas apparently, I'll make some suggestions.
If it is that low on power that it can't provide 15hp you'd notice it on the road (e.g. pulling a trailer uphill or even with tractor on its own.) If tractor seems ok I'd be questioning pump hp requirement or else its actual mechanical well- being. There's not a choice of gearing for the pump or anything odd like that?
If tractor is short of power and has just been rebuilt it could be many things. Make very sure air inlet system is clear (no old socks stuck in there. If its getting enough air, fuel system, valve timing or injection timing are possible causes too. Fuel lift pump has a filter screen that you could check. Check fuel tank cap vent hole is clear. You can undo inlet pipe to injection pump and turn the engine on the starter to see what comes out. Lots of diesel hopefully. Bleeding of fuel system will probably be needed afterwards. Were injectors also serviced? I would say to eliminate everything else before suspecting the injection pump. Its rarely faulty and is an expensive item to replace. (we did just that when the fault was a blocked air filter, which was very stupid and an annoyingly expensive blunder to make!)
