MH Pony Carb
Pat
05-28-2003 11:00:52
Well we finally gave up after exhaustive tries to fix the Pony and took her to a repair place. The problem we have is she starts strong and then about 1 minute later just dies. You can start her right back up again, but she won't stay running. We have replaced practically every part except for the internal governor and the actual carberator body. Here is the point, the repair place checked everything we did and they "think" that it is the carb body. Telling us it may be warped. My thoughts here are where do I get a carb body and is that really the problem. Anybody got any ideas.....
Nathan
06-09-2003 09:43:18
 Re: MH Pony Carb in reply to Pat, 05-28-2003 11:00:52
Tell me if you have it going yet. I may be able to help.
Tracy
05-31-2003 21:34:12
WOW....your's must be the brother to mine. I have a recently purchased 53 Pony that does the same thing. I have not looked deep into the problem as of yet, but the story I have been getting is dirt in the carb also.....let's hope so! Good luck.
billy
05-29-2003 19:23:32
put a 4 barral on the little guy,let it eat some fuel. C'mon man,wheres your sense of power?
Chris Todd
05-29-2003 19:15:39
Hi Pat,
I had a cub with a warped top (visible without gasket) from someone banging on top and overtightening screws. Was given a tip and and fixed warped top by shimming up with small finish washers(3 or 4) between top and bottom of carb halves at each screw. Then used pressure at warped spot to bend even with rest of carb section. go slow and easy....but it worked for me. Good Luck, Chris Todd
Chris Todd
05-29-2003 19:18:33
 Re: Re: MH Pony Carb in reply to Chris Todd, 05-29-2003 19:15:39
Me again, Have you tried leaving the fuel cap off also? Not familiar with ponys but may not be venting properly. Chris Todd
John
05-29-2003 16:05:33
Hi Pat
The same thing was going on with my pony turned out to be the float wings were bent as to rub on the side of the bowl which wouldn't let the float drop far enough to open. Hope this helps John
glenn
05-29-2003 11:30:18
my MH50 did this last year, caused by the fuel filter in the sediment bowl being 90% plugged. sufficient fuel could trickle into the carb bowl to allow it to start but not enough to keep it running. if you disconnect the fuel line entering the carb you should get a solid stream of fuel. seems obvious I know but maybe worth a try. tractor carbs are incredibly simple devices...why would it decide to warp after all these years???
bill
05-29-2003 18:43:47
 Re: Re: MH Pony Carb in reply to glenn, 05-29-2003 11:30:18
I had the same problem with my Pony. I replaced the sediment bowl & screen and ran a pipe cleaner through the fuel lines soaked in carb cleaner. That helped but didn't fix it completely. Each time it quit after that I pulled the carb off & cleaned it out. Now it runs like a top. A little dry gas in the fuel is a good solvent too. I know it sounds too simple & good to be true but for me it worked. That little carb is very sensitive to any contamination. Good luck.
Pike
05-29-2003 17:07:35
If you get things running and don't have an inline fuel filter after the sedement bowl, cut one in. It will save lots of trouble as the sedement bowl is somewhat crude technology.
Pike
05-28-2003 18:25:06
Are you sure you're not pulling a vacuum on the gas tank? Have you tried running it without the gas cap on the tank?
Pat
05-28-2003 18:41:54
 Re: Re: MH Pony Carb in reply to Pike, 05-28-2003 18:25:06
Yep, we tried without cap still did the same thing. We definately feel it's some kind of air/fuel drama going on.
