T.O. 35 gas MF 1956
Doug hargrave
05-26-2003 05:16:55
I am having no fire at the plug to start up my TO35 my switch is getting replaced, and my push button will be replaced and the points have been reset and cleaned with no oil on the contact pionts so what is wrong??? and what do I replace next?
Phil (VA)
05-27-2003 14:33:22
 Re: T.O. 35 gas MF 1956 in reply to Doug hargrave, 05-26-2003 05:16:55
If you are getting no fire at the plug, and you have a good battery, and you have replaced the things you said, it likely is either the coil or the condensor or maybe the distributor cap. The condensor is cheaper to replace first, and if the cap is cracked you might be able to see it. You didn't give the circumstances, like if it happened suddenly, or you hadn't started it in awhile, or if it cut off when hot, etc., which are details that might help diagnose it. You can jumper around the ignition switch to test it. I don't think the push button will be the problem if the tractor engine turns over.
Tammy
06-11-2003 09:38:31
 Re: Re: T.O. 35 gas MF 1956 in reply to Phil (VA), 05-27-2003 14:33:22
Had the same problem, there is a safety switch that sits on the blaoc follow you wirese to it , take the 2 wires out tape together and it should start, if it does you just need to get that safety switch replaced
