MH 30 hydraulics
Make mine a Mas
05-25-2003 18:32:00
I am in process of tearing down a MH 30 , it has an oil line leading from Hydraulic reservoir to engine block . what does this line do? Does engine oil mix with oil in tank? Stupid questions , but manual doesn't have answers.--Bill
Matt
06-03-2003 19:14:05
 Re: MH 30 hydraulics in reply to Make mine a Massey, 05-25-2003 18:32:00
The first guy was right. It is just a vent to insure that clean air replaces oil as it is pumped out of the system to prevent dirt build up in the hydraulic oil.
brian
05-29-2003 19:06:23
I have 2 30 tractors and the line you are talking about is a breather that goes from the top of the hyd. tank to the crankcase
ken
05-26-2003 17:51:36
Hi Bill The lines are for an oil cooler for Hyd & trans oil .The mf 25 has the same set up hope this helps Ken
Alberta Mike
05-26-2003 15:01:26
That's a strange one ... exactly where on the block is this line going to (or coming from)? There are a few places on that block where oil lines are located, some under pressure and others for oil draining back without pressure. Maybe this would give us a clue. Make sure you remember right or left side and exactly where.
