MF 285 differential locked up
not the pedal!
M Billington
05-25-2003 14:35:23
While holding down the left brake pedal, the differential locked up. The differential locking mechanism and pedal appears to be fine. However, the wheels are locked and remain locked in both forward and reverse. The tractor will run, but as you can guess, turning is a real pain! The pin that contacts the pedal and pushes into the differential will slide in and out when I push the pedal down. Can I access the necessary area by removing the plate under the seat? Anyone had a similar issue. It seems that something has broken inside the housing? Is there a spring that should be unlocking the differential? Any help is greatly appreciated?
Thanks guys.
mohsen mohammady
09-18-2003 22:55:56
 Re: MF 285 differential locked up - not the pedal! in reply to M Billington, 05-25-2003 14:35:23
we are looking for many of front axle mf285 with auto diff.lock.
do yo can help us.
pleas connect to us.
sarrin ebekar.co
best regards.
