MF 175D air in fuel
Farmer Fred
05-22-2003 18:12:08
Our MF175 keeps getting air in the fuel system and needs frequent bleeding. Sometimes once every hr in the field. Where can air enter the system?
The tractor runs and starts great.
Bob
05-30-2003 18:46:01
 Re: MF 175D air in fuel in reply to Farmer Fred, 05-22-2003 18:12:08
I had the same problem with a 165. The culprit was a cracked diapraghm in the fuel transfer pump. I couldn't see the crack until I held it up to the sun.
05-27-2003 05:26:17
Had something similar on an old crawler once. It was the rubber bushings on the fuel line to the filters. Replaced them and it fired right up.
How are the filters? Check around the sediment bowl also, they can suck in air that way too. Also check to see if the fuel return line is clear. Mike D.
