Hi, Question about MF 65
Lyle (Sask)
05-21-2003 09:09:26
I usually hang out on the Ford Board as I currently have a 2N for my acreage.
Someone in my town has a MF 65 for sale.
It is painted yellow, is a gas engine model.
It has a pretty sturdy MF Loader on it,that seems to run of a front mounted HD pump on the engine, and a rear standard hitch with a remote HD with 2 standard couplers.
The strange thing is that it has no PTO installed, (Cover Plate where one should go), and it also doesn't have a 3Pt hitch.
So, I'm assuming it's some kind of special purpose industrial model.
If I found the right parts at a wrecker could I reasonably easily get back 3Pt and PTO capability on this unit?
The guy who owns it is pretty proud of it, He's asking $3500.00 Cdn for the tractor and one of the very large rear tires is pretty severely weather checked on the sidewall and looks like it's got a slow leak.
Sheet Metal is all original, but pretty well beat up.
So is this tractor worth ~$2800.00 US as it sits ?
Thanks in advance for your responses ...
Lyle (Sask) THANKS
05-23-2003 14:43:33
 Re: Hi, Question about MF 65 in reply to Lyle (Sask), 05-21-2003 09:09:26
Thanks for the replies... So the work required to add the 3pt and PTO to a utility is probably not worth it is it ?
I'll keep my eyes open for a Farm Model, as it would suit my needs on my acreage better.
Lyle.
Big Dean
05-23-2003 21:35:37
 Re: Re: Hi, Question about MF 65 in reply to Lyle (Sask) THANKS , 05-23-2003 14:43:33
It all depends on what is there. Some of the Industrial tractors that did not have the pto & three point did come with the Hydraulic pump & liftcover with controls installed. One of those it would not be to bad to install the PTO & lift arms. If the Pump & liftcover is not there parts would be rather expensive. I am guessing probably at least $1500 to $2000 from a salvage I have not done one in over 10 years so really can't say for sure.
B.C.
06-08-2003 18:39:31
 Re: Re: Re: Hi, Question about MF 65 in reply to Big Dean , 05-23-2003 21:35:37
I've been away for a while. Do you know where a guy could find a rebuild kit for a MHF 50 hydraulic pump these days. I used to get parts from Central Tractor but guess they're gone.
Thanks in advance.
Big Dean
05-23-2003 11:56:08
That is probably an MF65 Utility they were part of the industrial line of Massey Ferguson tractors it is not uncommon to find the industrial tractors without the three point & pto. It probably had a backhoe on it originally email me if I can be of further help.
Boss Hog
05-23-2003 11:43:24
Around here, it's worth the price you mentioned easily.
Especialy with a good loader, which it sounds like it has.
