Low Ash Oil For a Ferguson?
JEH
05-18-2003 09:01:24
Is a low ash oil recommend for a fifties model TO-35 Deluxe (Gas)? I've read that low ash oils are recommended for tractors that are NOT worked hard. I've also read that low ash oil will minimize carbon build up on spark plugs. I use my '55 TO-35 for finish mowing weekly (four acres) which I consider light use. My tractor burns some oil and fouls the spark plugs. It will likely continue to do so until the budget permits an engine overhaul. Until then I'm using a "hot" spark plug but I will also buy low ash oil if it will help minimize plug fouling. Thank you for your recommendations in advance.
JEH
Tom
05-19-2003 07:43:33
 Re: Low Ash Oil For a Ferguson? in reply to JEH, 05-18-2003 09:01:24
Choices:
1. Mobil Delvac 1300 15W40
2. Shell Rotella T 15W40
3. Pennzoil Long Life 15W40
4. Chevron Delo 15W40
