Temp gauge
Tammy
05-16-2003 05:43:29
I want to replace my temperature gauge and idea of how to do this. I have a gas MF TO-35
Doug
05-16-2003 05:47:47
 Re: Temp gauge in reply to Tammy, 05-16-2003 05:43:29
yes Tammy, I am doing that as we speak, you will have to buy the whole assemble all the way to the top water hose inlet which is where the temp sending unit is. you will have to unscrew it and replace that and the line and the gauge. This will be tough at the sending unit depending on the age it has been in the housing. You can go two ways either the original Massey set up will run you $40 or get a after market at a car parts store for $15 make sure you get the right one the probe on the sending unit is different lengths so bring the old one to match. Hope this helps you and happy riding and shifting
Tammy
05-16-2003 06:30:17
 Re: Re: Temp gauge in reply to Doug, 05-16-2003 05:47:47
Doug thanks, one more thing maybe you can help. I replaced my coil on a MF To-35 gas, with a 6 volt, should I have gotten a 12?
Doug hargrave
05-26-2003 05:22:30
 Re: Re: Re: Temp gauge in reply to Tammy, 05-16-2003 06:30:17
yes well depends if your system was 6 volt, I would change everything to 12 that way everything is current and you can use stronger light bulbs and just more juice all together. not sure if it will work, it might for a while ,let me know how it does, Doug
