M.H. pony
Sam F.
05-13-2003 17:59:23
Have 1949 Pony that spark is not very hot. I know nothing about this type of tractor and wonder where I should start. So far not running. Plug type ?? Points look new ?? Does it have resistor wire or voltage drop ?? I installed new 6 volt battery is all so far. Thanks
Tracy A. in Cincinnati
06-04-2003 21:22:11
 Re: M.H. pony in reply to Sam F., 05-13-2003 17:59:23
I tried to put resistor wire on my 1953 Pony and it wouldn't even start.
Best stick with the solid wire. Good luck.
Guy R
05-15-2003 20:39:31
1. If the coil is hooked up backwards, spark will be weak. I believe Ponys were a battery positive ground system
2. As far as I know, all 6 volt systems do not use a ballast resistor or resistor wire. Full 6 volts to coil. 3. The engine works best with solid metal core plug wires. Sometimes I've seen people put in carbon core radio supression wire (made for a car) which weakens the spark.
