MF 50 3 point lift not strong and not traveling far enough
Sonny Hill
05-13-2003 06:07:58
I have a mf 50 the lift is weak and does't travel
up high enough. Is there an adjustment I can make to correct this. Is there some way to check the pressure and how much pressure should I have on my hyd.
Oldfarmboy Jim
05-17-2003 23:51:45
 Re: MF 50 3 point lift not strong and not traveling far enough in reply to Sonny Hill, 05-13-2003 06:07:58
Before you make any adjustments, check the filter in the hydraulic sump. If that's clogged, all the adjustments in the world won't improve the performance. These things are often neglected for years. The filter sits below the inspection cover on the left side. It's where your PTO lever is. Hope for an easy fix. JIM
Bill
05-13-2003 18:19:53
The IT manual does a pretty good job of explaining the adjustment you need as far as height. I would recommend you get a parts, service and owners manual too.
Bill
