Power adjust rims/clamp stops function location?
Will
05-12-2003 15:01:17
On my MF135D I just replaced my calcium ate up rims with new ones,and can't remember if the clamp stops/locking clips were tight up against the clamps holding the rims to the hub or not. I had to order new locking clips/stops as the original clips/stops were drilled in a way that didn;t match the new rims. When I put the new clamp stops on now there is a 1/2" gap between the clamps and the stop/clips. There was only one locking clip/clamp stop per rim on the original rims and the replacement rims were only drilled for one each so I'm assuming that's adequate, even though it seems as if other rims I've seen had locking clamps on all four rails. If the purpose of the locking clips/stops is to keep the tire from spinning I would think there would be 8 clips/stops per rim, one on each side of all the clamps. Sorry for the long post, this is the first itme I've fooled with the back tires.
David B
05-13-2003 05:22:44
 Re: Power adjust rims/clamp stops function location? in reply to Will, 05-12-2003 15:01:17
I am not sure they were intended to keep the wheel from spinning in the rim while you are using the tractor or if you move this stop where you want the wheel located and then spin the wheel out against it while adjusting it. It is used for both reasons and I leave mine so during forward travel it a safety to keep the wheel from moving any farther if the wedges don't hold. My wheel never slips in the rim on a M-F 65.
