MF35
Larry
05-12-2003 13:55:51
I have a MF35 gas tractor that has been a pretty reliable tractor. While mowing it started making an awful noise in the front of the engine. It sounds pretty loud. I haven't run it since, but have started again and it starts fine, no noise while starting, only after it's running. Any ideas?
James, UK
05-13-2003 01:56:03
 Re: MF35 in reply to Larry, 05-12-2003 13:55:51
Sounds like it could be a big end bearing (on the crankshaft end of the con rod) on its way out.
Not a big job, but do it sooner rather than later otherwise you will need to get the crank reground, $$$.
Replace all bearing shells including the crankshaft main bearings, as the loss of oil pressure due to the affected big end will have an adverse effect on the other bearings.
