TO-35
Tammy
05-12-2003 12:35:34
To-35 runs good for about 20 minutes and shuts off. I am about to give up on it. Is this major. I have put on new gas line , bowl from gas tank. I almost think it has nothing to do with the gas, what else could it be???
Tammy
05-16-2003 05:48:13
 Re: TO-35 in reply to Tammy, 05-12-2003 12:35:34
Are you ready for this! All the while I have been reaching out for help about my MF To-35 shutting off after about 20 or so minutes and got alot of wonderful responses from everyone, it is now fixed and fixed with a drink can. The metal fuel filter that I put on was up against the manifold and when it got hot it created a vaccum and stopped the gas flow. I placed a drink can in between the two and it runs until I shut it off. Now ain't that something. Thanks for all of your help.
James, UK
05-13-2003 01:49:53
Just passing through from the Ferguson forum but you might also change the ignition coil - they are famous for working fine when cold, and then breaking down when hot.
Checking them electrically is now a 'lost' art.
Good luck.
David (Scotland)
05-12-2003 12:47:57
Is breather hole in tank cap clear? If not it might be getting to the stage that gas won't run out of tank because of vacuum forming. Other possibilty might be a vapour lock forming in a fuel pipe if its routed beside anything hot, particularly if it as also at a high spot in pipe run. Spark plug insulation could be breaking down when they get hot although that might be more likely to give a misfire.
And...? Don't know - just some guesses.
