MF 35 what is the draft lever for?
Tecumseh
03-17-1999 19:02:33
it's the lever right next to the lever that makes the arms go up and down. it doesn't seem to do anything except move the arms 3/4's of an inch
Gerald
03-23-1999 17:45:20
 Re: MF 35 what is the draft lever for? in reply to Tecumseh, 03-17-1999 19:02:33
When the hydraulics work correctly, the draft lever lets a plow up and down and sets the plow depth automatically so it pulls just as hard as you want it to pull. E.g. when the ground gets stickier it raises the plow, then the ground slips easier it lowers the plow. The draft lever is normally used with the lift lever nearly all the way up.
Gerald
Robert
02-14-2000 06:09:00
 MF 50 Thermostat question in reply to Tecumseh, 03-17-1999 19:02:33
