M.H. Pony Positive or Negative ??
Sam F.
05-11-2003 21:11:26
I just bought a Pony without the battery. Looks to be positive ground ?? Is this correct ?? Also, are they 6-volt ?? Any site that sells reproduction carb. linkage, or will I have to "e-bay" it ?? Thanks guys, you're super !!
ENNISMORE.MIKE
05-13-2003 07:38:54
 Re: M.H. Pony Positive or Negative ?? in reply to Sam F., 05-11-2003 21:11:26
I installed a 8 volt battery in my massey 102 jr. It worked very well , didn't seem to effect the electrical system. The 8 volt battery is the same size as the old 6 volt battery.
ACB
05-12-2003 02:58:08
My '50 Pony is 6 Volt Postive Earth. I use a truck battery on it, most available 6 volts haven't got enough grunt especially if you're doing a lot of stop/start work or working under lights.
Guy R
05-13-2003 09:51:44
 Re: Re: M.H. Pony Positive or Negative ?? in reply to ACB, 05-12-2003 02:58:08
8 volt battery will work fine, just adjust the voltage regulator to deliver about 8.5 volts output from the generator. Otherwise the 8 volt battery will never charge properly.
