Mf 50a industrial backhoe
dj
05-11-2003 19:25:55
Ineed help. thats the bottom line . think you know something then get wipped. I dought an mf 50 A industrial backhoe today. The thing is about a 1974 with plenty of hydraulic leaks. Found where the trans fluid goes but not hydraulic fluid. Can someone please explain. Not like on old 8N. Thanks DJ
Bryan
05-13-2003 10:05:21
 Re: mf 50a industrial backhoe in reply to dj, 05-11-2003 19:25:55
The filler for the hydraulic fluid on my 50a (about 1971) is on the right hand side of the steering wheel just above the valves for the front bucket. It has a breather on the cap. It just unscrews and you take a funnel and pour fluid in. The fluid level needs to be kept well above the pump intake line but about 8-10 inchs below the filler cap. If you overfill it will let the extra out the filler cap when it gets hot which makes a big mess. I use a piece of wire as a dipstick to gauge the level. Mine has several leaks and I have to check it often (along with the other fluids). I have also had two cylinders rebuilt to stop them leaking which can get expensive as the cylinders on mine are metric (made in Canada).
