TO-20 BATTERY LOSING CHARGE
Mike in Delawar
05-11-2003 07:33:45
I am looking for some advice on my electrical system. I have a 1951 TO20 which I have owned for two years. I have a fairly new battery (replaced towards the end of last summer) and I am showing a charge on the ameter.
First, is it possible to show a charge on the meter and the battery not charge?
Secondly, can anyone suggest a troubleshooting approach I should use to narrow down the problem?
Thanks for any suggestions.
James, UK
05-13-2003 02:06:31
 Re: TO-20 BATTERY LOSING CHARGE in reply to Mike in Delaware, 05-11-2003 07:33:45
Just visiting from Ferguson forum - but I would almost bet you changed your battery because the old one lost its charge as well?
Sounds like you have a 'leak' while everything is switched off, so the battery drains quietly when you're not looking. To check this, put a meter (set to current) in series with one of the battery leads and see if there is a drain. Then check your wiring carefully against a wiring diagram - look for short circuits and frayed insulation. Check it all with a meter.
Listen for a 'click' in the control box when you reconnect the battery (with ignition etc switched off) - this will give you a clue to a slow leak as well.
CH
05-11-2003 11:53:36
How much of a charge? Remember, your using power to fire the sparkplugs. It's going to charge a little while it's running. The true measure of a problem would be if when you first start up, the ammeter goes way up for more than 30 seconds or more.
Check your battery connections and big cables. any resistance in those cables will cause a charge condition.
Could also be your voltage regulator.
