MF50 Hyd. problems
Kris Hockstedle
03-17-1999 10:46:48
On my MF50 the hydraulics have started locking in the up position. It doesn't do it all the time but once it does I have to relieve the pressure to get it to go back down. Does anybody have any idea what might be causing this?
Thanks Kris
Robert
03-18-1999 12:44:56
 Re: MF50 Hyd. problems in reply to Kris Hockstedler, 03-17-1999 10:46:48
On this site there are videos available that deal with the MF 50. I own a 50 and bought the video on rebuilding the hydraulic system ( I also got the one on engine rebuilding.) I really recommend them as they deal specifically with this tractor and do a good job of it. On this specific problem I concur with the previous advice about the spool problem but as the video explains: don't leap to the more complex analysis until you have ruled out the simpler ones. Additionally, if you are having this kind of a problem your system probably will benefit from a refurbishing in other elements and the video will get you through that too. Good luck.
bill beck
03-17-1999 15:50:56
Sounds like a spool valve problem. Clean and inspect valve for burrs. Loosen a hose get a sample to see how much hose residue and dirt is in the system; clean suction screen and replace filter; new fluid in system. Make sure there is not a machanical bind in the loader itself. good luck
