MF-65 Dies at full throttle
George
05-06-2003 18:51:41
My MF-65 dies after running at full throttle for a few minutes. It won't start for a few minutes later. After restarting, it runs fine at idle. When opening up to full throttle it does the same thing again.
I've pulled the fuel line off the carburator and it seems to be getting plenty of gas. I've disassembled and cleand the carburator. I've replaced the points, coil, condensor, cap, and rotor. Any idea's?
James In MO
05-06-2003 19:02:28
 Re: MF-65 Dies at full throttle in reply to George, 05-06-2003 18:51:41
Two things your float level in your carb is not set right or you have some rust in your sediment bowl tube or in you float inlet your book will tell you what to set your float at see my post in the problem right before yours
