MF 3pt. Disk Harrows
Help!
Eric
05-06-2003 09:12:37
I am thinking about purchasing a set of Massey Ferguson 3pt. hitch disk harrows and am trying to find more information. They appear to be in good shape and the guy is asking $500 for them. I am interested in finding out: what model they are, how much they weigh, and how they might compare to a new set of disks. A photograph of them is listed in the implement photos section of this WWW site. Link Thanks
Boss Hog
05-08-2003 05:09:57
 Re: MF 3pt. Disk Harrows - Help! in reply to Eric , 05-06-2003 09:12:37
Pretty sick, asking about something for a JD tractor here, don't ya think ???..... ..... ..... ..(-:
I saw an MF disk just like that one go for $500 at an auction last year, so don't pass it up. They're pretty rare around here.
We always used a 7' Oliver 3-point disk on our TO35, and I thought it worked fine. Was maybe a bit heavy, but not bad. You can always carry it a bit if you get in tough going. Or have an MF tractor pull it for you..... ..... (-:
If you don't end up buying it, how about posting here about it so someone else can have a chance at it?
As far as weight - I'd guess around 300 or400 pounds.
Chip
05-06-2003 10:13:24
They look Okay, but what type of tractor are you using? I wouldn't exceed 5' on a 35, and you can buy a new 5' disk for under $500.00. But from the picture, it looks like a stout set, so they may be worth it. Good Luck.
Eric
05-06-2003 17:22:07
 Re: Re: MF 3pt. Disk Harrows - Help! in reply to Chip, 05-06-2003 10:13:24
I would be using them on a John Deere 1020 - which has something like 32 horsepower at the drawbar (when new). I am kinda wondering if the disks are going to be too much for the tractor to handle - any thoughts?
chipmf35d
05-07-2003 08:20:05
 Re: Re: Re: MF 3pt. Disk Harrows - Help! in reply to Eric, 05-06-2003 17:22:07
The MF 35 has about 35 HP. I used to pull a 6' disc, and it did okay, but the 5' did better, plus I could pass through just about any space I could get the tractor through. (Long story) But if your JD has 32HP, I think you'll be fine. I have a friend with a Ford 1700 (25hp) and he can pull 5'.... works hard, but it gets done. So you should be okay.
