MF 50 HYDRAULIC LIFT WONT COME DOWN
JACK
05-03-2003 18:51:26
lift arms will not go down when tractor is running removed pump and freed up hydraulic cyl. tractor ran good for acouple of hours of disking then would not go down again ! any help
CH
05-04-2003 18:54:01
 Re: MF 50 HYDRAULIC LIFT WONT COME DOWN in reply to JACK, 05-03-2003 18:51:26
Here's some interesting reading.
http://www.tractorsmart.com/../MasseyServiceTips/Massey%20Ferguson%20Three%20Point%20Lift%20Description.htm
Robert Conibear
08-31-2004 12:55:08
 Re: Re: MF 50 HYDRAULIC LIFT WONT COME DOWN in reply to CH, 05-04-2003 18:54:01
Did you ever resolve this problem as I have just purchased a 135 with the same thing. Lift arms will only go down with the engine off.
Thanks
doug
05-04-2003 11:17:52
Try double checking the hydraulic fluid level.
I had a similar problem on my John Deere 955: the 3 pt rockshaft arms were stuck in the up position whether the tractor was running or not. Adjusting the float, etc. did not help. My fluid was very low & adding some solved the problem.
Doug
Bill
05-04-2003 09:06:47
I am no expert, so take my advise with a grain of salt, but it sounds like your control valve is stuck.
Also, the lift on my MF50 was very slow to lift and even slower to drop. Turns out that an old remote was frozen about 95% open preventing the lift from working properly.
Bill
