MF130 Perkins Engine/related parts
Wade Barry
05-03-2003 13:16:05
Have a MF130 which has engine coolant leaking into base in one cylinder; have confirmed by removing base and pressurizing coolant system, slow "green coolant" drip can be seen underneath one cyl., engine runs OK but don't want to use without doing proper repair.
I'm wondering where I might be able to buy cyls. sleeves, cyl. sleeve seals, head gasket, oil pan gasket, etc. (depending on what we find once we do a compression check - any idea how many PSI?)
I do have the Operators manual only and I understand that it was manufactured in France.
Tractor Model No. is: "1308SNMY"
Tractor Serial No. is "386698" Engine No. is "107FA7814" (stamped in block at injector pump mounting area, at the top of the block.)
Casting no. on top/front of the head: "37116400"
Casting No. on base of oil pan: "PF99-29413" "SFAR2712" (F might be an E)
Thank you in advance for any help.
Glen Evans
05-03-2003 14:12:01
 Re: MF130 Perkins Engine/related parts in reply to Wade Barry, 05-03-2003 13:16:05
Wade,If you need a workshop manual you can get one from the following place.
technical publications
5 vines avenue
london
N3 2QD
TEL:-02083431218
web site www.tracor-manuals.com
price was �12 plus �1-25 p&p
we have just last week required a mf130 and have had a manual off them.
as for engine spares you should be able to get them from a perkins dealer. if you need help i can
let you know of a good dealer in shropshire.
Wade
05-04-2003 05:36:46
 Re: Re: MF130 Perkins Engine/related parts in reply to Glen Evans, 05-03-2003 14:12:01
Thanks Glen. The MF130 is not very common here (in Nova Scotia, Canada) and the MF dealers struggle to provide certain parts. I have made some inquiries to local Perkins dealers. If I have no luck, I will take you up on your suggestion re. a good dealer in the UK.
Thanks again,
Wade
