Pony six volt
Randy
05-02-2003 05:37:34
I have a '49 Pony that when I got it the six volt battery was negative ground, is this correct? It runs good, little tough starting and doesn't charge well. Should I change it to positive ground or leave as is?
Thanks
Pike
05-02-2003 18:39:37
 Re: Pony six volt in reply to Randy, 05-02-2003 05:37:34
If you ever need to replace the battery, try putting an 8-Volt battery in. It will have a lot more pop and no other changes required.
Randy
05-02-2003 19:32:39
 Re: Re: Pony six volt in reply to Pike, 05-02-2003 18:39:37
Positive or negative ground?
Randy
Alberta Mike
05-02-2003 09:26:09
If it is the original 6V wiring system then it should be positive ground. What happens to the ammeter reading when you start it? If it shows a charge when starting then things are backwards wither at the ammeter or the battery hookup.
Randy
05-02-2003 19:24:04
 Re: Re: Pony six volt in reply to Alberta Mike, 05-02-2003 09:26:09
It shows negative on start load.
Randy
Don Q
05-03-2003 10:35:47
 Re: Re: Re: Pony six volt in reply to Randy, 05-02-2003 19:24:04
another clue as to how it is wired would be at the coil. If it wired positive ground, as it was originally, the "hot" side of the coil, coming from the ign switch, whould be at the negative post of the coil, and the positive post would be the side going to the distributor.....
