Remote plumbing on a MF 231
VA cutter
05-01-2003 17:43:52
I have a Massey 231 that I would like to run a sickle bar mower on the three point hitch. My question is how do I hook up the remote hydraulic plumbing to this tractor's system in order to operate the bar lift? Is the tractor's system set up for 2 way hydraulics or can a single acting cylender work on this system? My thought was to set up one remote valve with ports at the rear of the tractor. Thanks
Big Dean
05-02-2003 14:03:11
 Re: Remote plumbing on a MF 231 in reply to VA cutter, 05-01-2003 17:43:52
Most of the valves that replace the transfer cap on the lift cover to use the three point pump can be used on either a single or double acting cylinder.
