TO-35 Deisel Head bolt torque specs
Tom Pilcher
04-30-2003 07:14:08
Can someone provide the torque specs for my TO-35
Deisel.
TO-35 man
04-30-2003 15:18:26
 Re: TO-35 Deisel Head bolt torque specs in reply to Tom Pilcher, 04-30-2003 07:14:08
On a standard engine head bolt torque is 100 to 105 ft.pds. start from center working outward in X pattern if usuing an orignal style gasket the copper side faces the block.....valve lash is 0.012 intake and 0.008 exhaust intake valve stems use wear caps and exhaust have free style rotators. They are different so check them closely. hope that helps you...
Mike
05-03-2003 23:48:43
 Re: Re: TO-35 Deisel Head bolt torque specs in reply to TO-35 man, 04-30-2003 15:18:26
If it is a perkins A3-152, it is 60 ft-lbs
