Masse Ferguson 65 screwup
Don
02-11-2000 19:52:31
Hi, I got a Gas powered Massey 65. Putting new plug wires on it, I may have them in wrong order. can someone give me the proper firing order? And I noticed the cap is not marked 1 hole, like the Farmalls are? Thanks for your help.
B.C.
02-12-2000 01:02:10
 Re: Masse Ferguson 65 screwup in reply to Don, 02-11-2000 19:52:31
Check the tune up specs on the link below. Number 1 is closest to the fan. Bump the engine over with the dist cap off to get the rotation and that should get you the firing order squared away.
You might want to check the point gap and so on.
There should be a removable plug in the forward face of the flywheel housing immediately aft of the distributor. You can shine a timing light back in there to check the timing marks which are on the flywheel face itself.
Should be straightforward. Good luck.
