Fix a flat products/do they work?
Will
04-29-2003 04:15:36
Sunday afternoon I bushogged for a couple of hours and heard my left rear tire leaking when I shut off my MF135D. The leak is right at the rim where the tire bead seats. This is really annoying as I just paid for calcium draining and new tubes three months ago (the tire company won't warrant their work). Any comments on the fix a flat/flat stop products offered for sale at part stores? Does it hold up?
Jason
04-29-2003 12:15:25
 Re: Fix a flat products/do they work? in reply to Will, 04-29-2003 04:15:36
I don't think fix a flat is going to solve your problem. If it is leaking around the bead try putting more air into the tire. The bead might not be seated yet. Alot of times you have to put alot more air in at first to get a nice POP sound when the bead has sealed. Also alot of times when you put a tire back on there is air trapped between the out side of the tube and the inside of the tire. It has to excape some how. Alot of the times it will come out around where the valve stem comes threw the rim. Or around the bead if it isn't sealed right.
kypete
05-04-2003 00:01:46
 Re: Re: Fix a flat products/do they work? in reply to Jason, 04-29-2003 12:15:25
Takeit from an old tire man, fix a flat will not work in a tractor tire with a tube in it filled with calcium. It sometimes works in tubeless tires if it is just a small clean puncture. Even so, it is a temporary repair.
