Cute Massey with hydraulic loader leak
Quaker Oats
04-28-2003 19:12:52
Hey guys,
A friend of mine turned me on to a Massey Ferguson "65" with a factory loader. But, the loader leaks down after a few minutes while running, and really won't "hold" the tractor up. (it seems like a lot of people are proud of this, so I thought I would memtion...) Anyway, am I over reactioning by thinking this is a big problem, or would a few well praced seals fix this tractors problems???
Thanks, Kyle
CH
04-29-2003 08:09:18
 Re: Cute Massey with hydraulic loader leak in reply to Quaker Oats, 04-28-2003 19:12:52
Sounds like you need to rebuild your spool valves if your not loosing fluid. Once the oils in the cylinders when you raise them, the control valves hold it there.
howpark
05-11-2003 11:48:36
 Re: Re: Cute Massey with hydraulic loader leak in reply to CH, 04-29-2003 08:09:18
I have the same headache on my MF85. I have the 3 spool hydraulic setup. Also with the 3 pt hitch you have to set the lift lever in correct position according to the manual. I thought it was leakage on the 3 pt hitch raise/lower control that may be the problem. DID you redo the spools and did this solve the problem? Cheers.
