Harris or Ferguson... Older ?
vince
04-28-2003 10:55:13
Just recieved a Massey Harris Tractor and don't know model or year as of yet. This thing is a basket case. What I would like to know is which came first.... Massey Harris or Massey Ferguson? I know basically that they are the same company etc. but who's the forerunner? Thanks for the info. Regards
Bob
05-02-2003 16:31:02
 Re: Harris or Ferguson... Older ? in reply to vince, 04-28-2003 10:55:13
Look at the underside of the front casting (bath tub) just ahead of where it bolts to the transmission. There should be a date there. That will tell you when the tractor was built. As for the model, give us some details such as: number of cylinders, whether it is an overhead valve or L-head engine, number of forward gears, rear tire size and if the bath tub is cast iron or steel, and can narrow it down for you.
Alberta Mike
04-28-2003 11:31:12
Massey Harris was first, then it was Massey Harris Ferguson for a short time I believe, then finally Massey Ferguson. I think the first change when Ferguson got in was about 1953 but the company still labelled tractors as Massey Harris till maybe '58 or so.
Ken
04-28-2003 17:09:36
 Re: Re: Harris or Ferguson... Older ? in reply to Alberta Mike, 04-28-2003 11:31:12
I have two Ponys with 1954 serial numbers on which the data plate shows Massey Harris Ferguson.
The older ones just say Massey Harris. Don't know which year change was made.
