Power Steering Fluid
Mike B
04-27-2003 08:20:43
What type of P/S fluid would you recomend for a Massey Ferguson 245. I have a foaming problem. My local dealer told me to put tractor hydraulic fluid in the reservoir. But after 3 drain and fills it still foams.
Thanks
CH
04-27-2003 08:37:37
 Re: Power Steering Fluid in reply to Mike B, 04-27-2003 08:20:43
Same thing you use in the rear end, Permatran III.
Mike B
04-28-2003 20:46:00
 Re: Re: Power Steering Fluid in reply to CH, 04-27-2003 08:37:37
Thank you for your help, I received a great message from a retired Massey Mechanic with complete instructions for my problem.
Thaks Again
Mike B
RogeR
04-29-2003 06:22:42
 Re: Re: Re: Power Steering Fluid in reply to Mike B, 04-28-2003 20:46:00
Mike;
Would you mind sharing those instructions?
Thanks,
Roger R
Mike B
05-03-2003 18:55:37
 Re: Re: Re: Re: Power Steering Fluid in reply to RogeR, 04-29-2003 06:22:42
Here's Big Deans e-mail for MF 245 power steering blues. PS.. Thanks Again Big Dean
Have you bled all the air out of the system The dealer was right the same oil that is used in the Trans/Hyd Permatran 3 is what is used in the power steering on an MF245. if it is a diesel you fill it with the engine running & turn the wheels from stop to stop in both direction with the fill plug out till you have all the air bubble worked out. If your system has a lot of air in it you may have to refill the pump reservoir a few time as you work the air out. I have never figured out why they don't till you to do this in either the service or the operators manual. As a Massey Ferguson mechanic for 27 years I have fix many steering problems doing this on the diesel tractors. What ever you do don't use Dextron ATF in that system Hope this helps you. Big Dean Shawnee, OK. Big Dean's Massey Ferguson help web site Click here: Big Dean web Site
