Any Ideas
Redneck in TN.
04-22-2003 13:55:24
I have a 165 gas burner, it has developed a miss. I have changed plugs, points, wires, coil and rebuilt carb. The thing that gets me is it doesn't miss all the time. It doesn't matter if it is cold or hot, just cranked up or ran a while. I need some help here.
rod
04-23-2003 06:53:52
 Re: Any Ideas in reply to Redneck in TN., 04-22-2003 13:55:24
dist cap cracked? valve burnt or needs adjusted?
gas flow to carb restricted to carb, leaking carb gasket, cracked manifold. Just some things to check
regards
rod
Tom Dold
04-23-2003 07:06:09
 Re: Re: Any Ideas in reply to rod, 04-23-2003 06:53:52
Redneck
Broken valve spring.
Tom Dold
Ross
04-23-2003 20:31:05
 Re: Re: Re: Any Ideas in reply to Tom Dold, 04-23-2003 07:06:09
I sure sounds to me like its a spark plug problem. Try some older cheap plugs. The fancy new ones are prone to being bad.(Same thing happened to me)
bob
04-23-2003 21:33:15
 Re: Re: Re: Re: Any Ideas in reply to Ross , 04-23-2003 20:31:05
Bad condensor or condensor wired to wrong side of coil.
