Loss of P.E.S. and hydraulics MF 165
Mark McL
04-19-2003 01:08:42
While slashing with MF 165 the PTO, while in Proportional Engine Speed (P.E.S.), suddenly stopped working and the hydraulics also stopped working so that I couldn�t operate the 3 point linkage, however the PTO will operate while in Proportional Ground Speed (P.G.S.). When placed in P.G.S. and move forward then slip into P.E.S. and while the PTO shaft is still rotating, the 3 point linkage will lift until the PTO shaft stops spinning, but won�t hold. Is there anything inside the transmition such as a shear pin / sleeve that may stop P.E.S. & hydraulics from working?????
David
04-19-2003 04:02:17
 Re: Loss of P.E.S. and hydraulics MF 165 in reply to Mark McL, 04-19-2003 01:08:42
Sounds like the live drive bit of the dual clutch has failed. If you take off the side cover (where pto lever is) you may be able to see that things are not turning when they should be. I think after that you'd be looking at splitting the tractor to check out the clutch. There is a shear coupling in the transmission but I'm pretty certain its at the rear of the pump and would disconnect the drive wheels if it sheared. You can see it with the the side cover off.
