MF35 Fuel filter breather
is it necessary?
Laurence
04-15-2003 21:12:37
I am in the process of changing the engine of a MF35 from 4-cylinder gas to 3-cyl diesel. I got all the necessary parts from a local used spares dealer. The double diesel filter supplied has its breather pipe pinched shut. Is this breather necessary - with it shut where would the excess fuel go, but with it connected to the fuel tank won't too much fuel run back to the tank with too little pressure for the injector pump?
Nigel
04-16-2003 05:14:42
 Re: MF35 Fuel filter breather - is it necessary? in reply to Laurence, 04-15-2003 21:12:37
The fuel bleed line from the filter head is to bleed small amounts of air that may be in the fuel system. The banjo bolt securing the line to the filter head should have a restriction built into it. The lift pump used by MF will only pump about 5 PSI then goes into stand-by mode automatically. You can feel this occur as you hand prime the pump. Hence the answer to your question is no, but you may have difficulty bleeding air from system.
David
04-16-2003 03:03:06
I think you will need to connect it. I recently test ran a 3-cylinder with my thumb over the leakback pipe and it was ok but I doubt this would be satisfactory for longer term. One function of filter leakback is to allow air bubbles to bleed out of system back to tank. I think it would also create a back pressure that the lift pump might not like if it was closed off. The system also feeds fuel to the reservoir on the back of the tank that, in turn, feeds the manifold heater plug (which you won't need to use unless you're in a very cold climate)
Appears that restriction of pipe diameter is sufficient to create a back pressure high enough to feed fuel into the injection pump. Leakback is not under pressure so a suitable fuel resistant rubber tube does the job if you need to join two cut ends of pipe to make the connection.
