MF65 serial numbers and engine type
mike
04-15-2003 11:31:09
I am new to tractors and have a MF65 with the serial numbers "UNM 691054" I know it was manufactured between 1962 and 1963 by the serial number, but can anyone tell me what the UNM stands for? it also has a 4 cylinder diesel engine any ideas on the make and horsepower? it is yellow like an industrial with a "Midwestern Industries For Massey Harris Ferguson" loader.
thanks for any help
mike
Hamish ( Scotland)
04-17-2003 11:43:44
 Re: MF65 serial numbers and engine type in reply to mike, 04-15-2003 11:31:09
Hi Mike
from what i can gather, UNM before the serial number stands for
U Utility model
N diesel engine( not direct injection)
M dual clutch
If it was an industrial model it would have a J in place of the U.
Hamish
fergusonfan
04-15-2003 12:30:26
Your tractor is a late '62 according to my book. The diesel's got a 203.5 cu. in. Perkins engine. The prefix on your serial number befuddles me, unless it's something denoting it as being a utility industrial tractor. Hope this helps.
Hamish ( Scotland)
04-19-2003 11:15:17
 Re: Re: MF65 serial numbers and engine type in reply to fergusonfan, 04-15-2003 12:30:26
If it is a MK11 MF65 you have with the Perkins AD 203 engine it will have fuel injection and should have serial no UNDM, the D after the N denoting direct injection.The easiest way to tell between Mk1 and Mk11 is the size of the fuel tank. The Mk1 has small er square tank with space for two batteries ( it was designed for 2x 6v batteries) whereas the Mk11 has a larger fuel tank and space for only one battery (12v)
Could it be an earlier Massey Harris ?
John Manders
04-17-2003 06:08:54
The industrial 65's were 65R and 65S in UK. Mine is a 65S which has a shuttle transmission. That means that there is a rocking accelerator pedal which comnes as direction select. Press one side for forward and the other side for reverse. I think (but not sure) that the 65R has normal transmission.
John
