44 serial numbers
Jason
04-08-2003 19:24:02
Can someone tell me what I have, I belive it is a wheatland but not sure the model is 44G1SF and the ser. is 59646. I don't know the year ether.
thanks for any help
Jim from Ill
04-09-2003 09:22:12
 Re: 44 serial numbers in reply to Jason, 04-08-2003 19:24:02
Looks as if you have a 44 special. Some 10,719 were made, unless the tractor you have is a hi- crop or cane version, then it is very rare. Only a handfull were made and most were recalled. I cannot find that massey made a wheatland tractor in that year. Hope this helps.
Jason
04-09-2003 20:32:59
 Re: Re: 44 serial numbers in reply to Jim from Ill, 04-09-2003 09:22:12
The tractor is not a hi-crop, the rear fenders cover the tires about 1/3 the way around, and have a small platform between them. It has a wide front. Also the rear axles use a big nut to hold the wheels on. I don't know alot about Massey's I got this one over in Iowa on my way home from a sale.
marlowe
04-10-2003 16:05:29
 Re: Re: Re: 44 serial numbers in reply to Jason, 04-09-2003 20:32:59
you still can have a 44 special std. what size engine do you have 260 or 277 the no. is on right side of block at the head gasket line to the front
Jason
04-11-2003 22:20:19
 Re: Re: Re: Re: 44 serial numbers in reply to marlowe , 04-10-2003 16:05:29
The engine says 277. Is this a good engine? What are the bore@stroke?
marlowe
04-12-2003 14:02:12
 Re: Re: Re: Re: Re: 44 serial numbers in reply to Jason, 04-11-2003 22:20:19
that is a good engine it's the same as the 260 just a bigger bore not sure of size.so you have a 44 special std.
Jason
04-12-2003 15:07:40
 Re: Re: Re: Re: Re: Re: 44 serial numbers in reply to marlowe, 04-12-2003 14:02:12
THanks for all the info. What is this tractor worth?
marlowe
04-08-2003 20:05:00
1955
