Massey Ferguson 65 starting?
Tom
04-07-2003 12:18:09
Just acquired a non-running 65. Can't quite get it to turn over fast enough to start. When tried to pull to start it free wheels. Beside the gear ship lever is a second shifter with "H S L" but it seems to have only two positions... neither will engage the gears...
CH
04-07-2003 14:04:21
 Re: Massey Ferguson 65 starting? in reply to Tom, 04-07-2003 12:18:09
There are 3 positions on the second shifter. "H"igh range, "S"tart which is neutral and "L"ow range. The shifter must be in "S" position to have the starter crank (there's a safty switch) unless it's been jumpered out.
Richard
04-07-2003 15:24:05
 Re: Re: Massey Ferguson 65 starting? in reply to CH, 04-07-2003 14:04:21
If it free-wheels you may have a Multi-power tractor, these will not tow start.
buford
04-09-2003 19:09:40
 Re: Re: Re: Massey Ferguson 65 starting? in reply to Richard, 04-07-2003 15:24:05
free wheeling with both levers in gear you have a multi power tranny. some of the older 65 tractors require pre heating to start and a good battery. You might check sn. to see jf you have a early 1960s tr.if you use ether go easy with it you can do more damage htan good.
