Foul oder
Jim in Va.
04-07-2003 07:50:03
I've got a MF 35 diesel deluxe and it had a oder/smell that would burn your eyes if you were behind it. Was told to replace the injectors. I also pulled the head and looked at the valves, seemed ok, replaced head, gasket, and injectors. But it still burns your eyes! I adjusted the valves to .013. Changed all filters and fluids. Any advice? Great tractor, just can't stand the smell! Thanks in advance, Jim
Bill
04-07-2003 09:04:08
 Re: Foul oder in reply to Jim in Va., 04-07-2003 07:50:03
Does this foul odor smell like sulfer? If so, it might be your battery cooking due to a faluty voltage regulator.
Bill
Jim in Va.
04-16-2003 04:41:07
 Re: Re: Foul oder in reply to Bill, 04-07-2003 09:04:08
THANKS BILL; IT'S NOT THE CHARGING SYSTEM, THATS THE NEXT JOB. IT ISNT EVEN CHARGING . JIM
wiseguy
04-09-2003 05:13:25
Sure someone hasnt peed in your radiator?
Jim in Va.
04-16-2003 04:43:09
 Re: Re: Re: Foul oder in reply to wiseguy, 04-09-2003 05:13:25
WISE GUY? NOT THAT I KNOW OF. HAVE PISSED IN FRONT, ON THE SIDE AND IF IT'S NOT RUNNING, IN THE BACK. BUT NOT IN IT.
buford
04-09-2003 19:18:31
put in some fuel conditioner change to an up right exaust these little guys were bad for that, I have ridden on a tobacco setter pulled with a mf35 with a down exaust , man it will kill you
Jim in Va.
04-16-2003 04:45:26
 Re: Re: Re: Re: Foul oder in reply to buford, 04-09-2003 19:18:31
THANKS BUFORD. I'LL TRY THAT. IT RUNS FINE, JUST THAT SMELL! I WAS THINKING OF PUTTING THE TAIL PIPE UPRIGHT AS IT'S A KILLER WHEN YOU CHANGE TOOLS. JIM
