M/F 65 w/leak in bellhousing area
robert becker
04-06-2003 10:04:57
M/F65 diesel W/multipower(works)has strong leak of axle lub comming from bellhousing.Some have advised leak is trans input seal,others have advised mutli power is the problem.help!
PeterW
04-07-2003 11:13:02
 Re: M/F 65 w/leak in bellhousing area in reply to robert becker, 04-06-2003 10:04:57
I have just owerhauled the converter on my MF65 and it is screwed together with a rubbergasket, also the valve (forward/reverse) who reglates from right pedal is fixed in bellhouse. The oilpipe who goes to this valve looks wery week. If I had a leak from bellhouse I shuold take out starter to get idea. Check for pressure in transmission (if it leaking when oilfilling-cover is off).
PeterW
S. Smith
04-06-2003 19:46:40
If it only leaks with the multi power in high, I am pretty sure it is the input shaft seal and brass bushing that needs replaced and replace the two sets of sealing rings also. You will have to split the tractor.
