M/F 135 PTO wont disengage
robert becker
04-06-2003 09:52:05
135 gas w/4 cyl cont.clutch works correctly,but pto wont disengage
Paul
04-07-2003 05:33:00
 Re: M/F 135 PTO wont disengage in reply to robert becker, 04-06-2003 09:52:05
Was there any lead up to failure to diengage? You should be able to disengage the pto whilst the engine is off.
S. Smith
04-06-2003 19:50:46
I believe the pto clutch needs adjusted. The factory set is 90,000 but if the plate is warped a little, it will have to be set less than 90,000. It takes a 9/16 and 1/2 inch wrench and can be adjusted from underneath.
