WHAT THE HECK !!! WHAT DID I BREAK ????
Jerry C OK.
04-05-2003 09:53:54
MF 65 LP, let transmission get way low on oil. Started making metallic rattles as I was roading it home, shut off,pulled home. Refilled transmission, started it moved about 15' started rattling off and on. Both levers in netural,it locks up kills engine.Whats most likely, transmission or clutch or both ???? Thanks Jerry C
Thanks Guys looks like splitting time Jerry C
04-05-2003 20:22:11
 Re: WHAT THE HECK !!! WHAT DID I BREAK ???? in reply to Jerry C OK., 04-05-2003 09:53:54
appreciate the response, hadn't thought about loose bearing might be locking it up Jerry C
mhmalcolm
04-05-2003 15:27:06
Most likely a bearing has come apart and a piece of it has gotten caught between some gear teeth, preventing them from turning. I would probably start by removing the shift lever cover and the rockshaft housing to see if you can see where the failure is. Most likely a complete transmission tear down will be needed to inspect and repair other damage the low oil situation might have caused.
Gordon-(TN)g
04-05-2003 14:44:35
sounds like major problems in transmition to me,needs to be pulled and checked out, my guess would be all of the bearings need to be replaced,if you are lucky ,the gears are o.k Hope this helps
Gordon-(TN)
