Any Head gasket R/R tips MH44
Mark S.
04-04-2003 09:24:56
It looks like I'm going to have to change a blown head gasket on my MH44 4cyl. H260.
I have a manual, but it is not that detailed.
I'm concerned with removing the rocker arms.....
Any tips??
Thanks Mark
Mark S.
04-05-2003 09:41:39
 Re: Any Head gasket R/R tips MH44 in reply to Mark S., 04-04-2003 09:24:56
Thanks for the tip!I think I have a liitle more than a gasket problem, (2 cyls aren't firing)...
A local tractor repair shop was highly recommended to me, So I loaded her up and took her in for the repair. It's going to cost a little more but at least i will be done right.
Thanks Again!!!
Mark
marlowe
04-04-2003 13:43:58
it's no big deal just lay them out the way you take them off so you can put them back on the way they came off same with the push rods it's not a must but it's a little easyer also check push rods for wear on the ends and make sure none are bent. get head milled and check block for trueness and make sure all is clean also you might want to do a valve job as long as you have it down cheep ins.
