Massey Ferguson TEA 20 (Petrol Engine)-Transmission Oil Problems
Matthew Nowell
04-02-2003 13:51:32
When I pour more than 12 Litres into the Transmission caseing the oil leaks out from a small hole at the underside of the flywheel/Clutch housing.I am using 30W 40W oil.The complete Transmission takes 22.8 Litres.Could it be that a seal is leaking and oil is getting into the clutch/flywheel housing? which I presume stays dry?(it is a drilled or cast hole made from manufacture, not damage),it is at the bottom of the housing.I have heard this hole is a saftey hole so that in the event of leaking oil getting into the clutch housing, it can escape?.Is there anything I could tip in the Transmission that would seal the leak?
The rear tray is not staying at full height once you lift it, it slowley drops, could this be due to low level of oil in the Transmission or wear in the pump and gearing?
Any advice appreciated.
Many Thanks
Matthew Nowell
CLUTCH
09-27-2004 16:58:20
 Re: Massey Ferguson TEA 20 (Petrol Engine)-Transm in reply to Matthew Nowell, 04-02-2003 13:51:32
IT SOUNDS LIKE THE FRONT SEAL OF THE TRANSMISSION IS LEAKING....
