Massey harris 44
ih puller
03-28-2003 12:41:35
ive been an ih man my whole life, but i am looking for a ffa restoration tractor and ran across a massey 44 gasoline tractor. its in pretty good shape, flathead 6 cylinder, decent rubber, and not many oil leaks. it also has a live hydrolic pump on it. narrow front end. i couldnt get the price or run it, the fellow wasnt there. what price range shuld i expect to pay for a tractor like this? how good of a tractor were they? does it have live power take off? ill be using it for everyday work also, bailing plowing planting firewood etc. any and all advice is appreciated. thanks derek
Farmman
03-31-2003 08:51:21
 Re: massey harris 44 in reply to ih puller, 03-28-2003 12:41:35
I own a 44-4 and it's a fine tractor. Plenty of power and very easy to work on. I've been real pleased with it so far. I refurbished it two years ago. Mine has a 44 special 270 engine in it. I paid 700.00 for it but it was not running right at the time and had lots of leaks. I see them around in the 1500.00 range a lot. My opinion.
SHANNON BONE
03-29-2003 21:25:18
I OWN MH 44 4 CLYINDER , THEY ARE MUCH EASIER TO FIND AND MUCH MORE DEPENDING THAN 6 CLYINDER... 4 CLYINDER IS MUCH MORE TORQUEY THAN 6 CLYINDER.. MH 44 WITH 6 CLYINDER ARE NORMALLY SELLS BETWEEN $1500 TO $2300 IN NORMALLY CONDITIONS.... BOTH 4 AND 6 CYLINDERS HAVE SAME HP RATINGS BUT 4 CLYINDER HAS ALOT MORE TORQUE THAN 6 CLYINDER, IF YOU RAN INTO SOMETHING HARD AND SLOWS REAL QUICKLY.. THAT 4 CYLINDER WONT EVEN SHUT DOWN THAT EASILY... IT WILL KEEP IT GOING... I HAVE 6FT ROTARY BUSHHOG AND I WAS CUTTING 7 FOOT BUSHES ALL OVER THE FEILD.. IT HAD NO TROUBLE AT ALL , AND REAL GOOD GAS USAGE... YOU LL BE BETTER OFF GETTING 4 CYLINDERS.. THEY HAVE 2 OF THEM, ONE IS H260 .. THATS 260 CU. INCHES AND OTHER ONE IS CALLED SPEICAL 44 WITH THEY ENLARGED H260 TO H277 4 CYLINDERS LATER ON... HOPE THIS INFO. HELPS YOU A BIT... GOOD LUCK GETTING ONE! THEY ARE PRETTY GOOD ONES!
David B
03-28-2003 17:20:44
They quit building the 44-6 ,1951, befor Massey had a continous pto available. Not quite as good a workhorse as the 4 cylinder but a real smooth runner. Probably not as long live between engine overhauls as the 4 cyl or as much horsepower. There were fewer of these tractors made than 4 cylinder models and I think because of this they have a little higher value for a collector but if you are going to work it the 4 cylinder is tougher and more powerful.
