MF 135
03-24-2003 06:43:39
I recently purchased a Massy Ferguson 135 but need help identifying it. The metal tag on the engine block has the seriel number at 5274. The engine has 145A on it. It has a conteniel four cylinder engine in it. It has a high/low transimmision with 6F and 2R. Can someone tell me what year. I tried the numbers to the left but they don't match my tractor. Also where would be my best source for some sheet metal for the front of the tractor in front of the radiator. thanks for any help.
Bob in CA
03-25-2003 13:31:06
 Re: MF 135 in reply to [email protected], 03-24-2003 06:43:39
Your tractor is most likely an early model 135 as the continental engines came only in the early versions. I can't tell from the engine number what year it is but on the early 135s the tractor serial number plate is on the right side of the battery box mount behind the air cleaner.
the serial numbers for the early tractors are as follows:
1964---641000001
1965---641001909
1966---641014871
Good Luck
Bob
