TO-35 pivot pin removal
Ted
03-22-2003 12:31:43
Trying to do a good job of cleaning and painting my fornt end, but can't get the pivot pin out from the front axle support. Tryed penetrating oil and pounding with pin inserted from the back of front axle inside of the pivot pin. Don't know what else to try? Am afraid of breaking face plate off of pivot pin. Do I need to use heat? Thanks Ted
Yankee in Tn.
03-23-2003 05:24:34
 Re: TO-35 pivot pin removal in reply to Ted, 03-22-2003 12:31:43
I had to replace the bushing in my MF35.To get the pin out I had to support the engine and unbolt the assembly.Then I could lay it down and drive the pin out from the back.It took some serious beating from a 6lb.sledge.Lube it up good with antisieze when you reassemble.Too bad they don't put in a grease fitting.
