Massey 175 pto will not engage
W.Brown
03-20-2003 12:36:28
massey 175 not multipower,has ground speed.pto will engage, but won"t engage with mower attached
Big Dean
03-20-2003 19:16:42
 Re: massey 175 pto will not engage in reply to W.Brown, 03-20-2003 12:36:28
It sounds like you have a dual clutch with manual PTO & the PTO clutch is slipping when you put a load on the PTO you can tell if this is your problem by trying to raise the three point when the PTO stops turning if it won't raise then you have a PTO clutch slipping. If the three point will raise when the PTO stops turning then you have Independent PTO & the clutch pack is shot. If I can be of further help Email me
Tom Dold
03-21-2003 14:24:24
 Re: Re: massey 175 pto will not engage in reply to Big Dean , 03-20-2003 19:16:42
If the M/F 175 has independent P.T.O it won't have ground drive pto. The ground drive pto was
on the tractors with live power (dual clutch).
Tom Dold DOld Implement Co. Howard, SD 57349
605-772-4541
